Results 1 to 2 of 2
Thread: defender problems all at once
    polky Guest
    hey how you going? just brought a 1999 110 and already having some problems. my aircon is leaking water everytime I use it, the clutch is making grinding/winding sounds when I change gears, my handbrake cable just snapped and I have a fist size hole in the firewall (knew it was there). need some help with these problems and a good site to buy parts.
    cheers guys
    Mar 2013
    Tasmania
    Quote Originally Posted by polky View Post
    cheers guys
    Aircon drain may be blocked or the hose may have come lose or the system is leaking further up before it even gets that far.
    [ame=http://www.youtube.com/watch?v=g9mWIyLeTk8]Willys MB: Squealing Noise from Throwout Bearing: solved! - YouTube[/ame] if your cluck sounds like this your throw out bearing may be on the way out. Drivable but make sure its replaced when a new clutch goes in.
    Carry a couple lumps of wood for wheel chocks & be mindful your peddles stop at the firewall and not the radiator.
