Results 1 to 2 of 2
Thread: 2005 110 TD5 AC Fan
    Dariusz Guest
    Question 2005 110 TD5 AC Fan
    Hi all, as a newbie in all Defender stuff, I have lots of questions, but are one that prevent me to sleep je je je.
    In a 2005 Defender 110 (TD5), with AC (fitted OEM) I can see a electric connector in front of the Air condenser (I see it if I look from the grille in front at my left hand). Some questions:
    1. Is this connector for a electric fan? I don't have a fan in this place .
    2. I need it to use the AC? (the temp never go high in traffic jams)
    3. Someone have the part number?
    4. This fan only start as the AC is turn on, or the ECU use it for something else?
    Thanks in advance for all the answers and help. Kind regards
    Dariusz W.
    Jan 2012
    Now in Sunny Perth
    Yes there should be an electric fan behind the grill on an A/C equipped TD5. The ECU does control this fan as it gets a signal when you switch on the A/C, it also will activate this fan if your engine temp gets to high.
