Results 1 to 10 of 19
Thread: Big Boy photos
    Brisbane, Inner East.
    Big Boy photos
    Here are some photos of Big boys 4014 and 4004 taken in June last year. I also have some of 4023 but my camera was playing up unbeknownst to me. The display was showing 800 ASA but it was stuck on 1600 ASA so I have badly overexposed photos. I will try to correct them as much as possible using the Nikon editing software or Photoshop.
    4014 was in the California State Rail Museum at the State Fair Grounds, Pomona. In November 2013 it was moved on temporary tack to a main line and pulled up to the maintenance yards in Cheyenne, Wyoming, where it is to be restored and eventually to pull excursion trains. This is expected to take 3-5 years.
    There are apparently eight survivors out of 24 built. Alco built 20 of them in one year, 1941, as well as carrying on their normal business. Can you imagine any Oz maker attempting that?
    The survivors are:-
    4004 Holiday Park, Cheyenne, WY.
    4005 Denver, CO.
    4006 St. Louis, MO.
    4012 Scranton, PA.
    4014 maintenance yards, Cheyenne, WY
    4017 Green Bay, WI.
    4018 Frisco, TX.
    4023 Kenefick Park, Omaha, NE.
    I would love to go on an excursion drawn by 4014 when restored.
    URSUSMAJOR
    Bearman's Avatar
    Hay Point
    They would have been an incredible engine in their time. Looks like two cylinders on each side. What sort of HP are we talking Brian. Any statistics?.
    Cheers......Brian
    1985 110 V8 County
    Quote Originally Posted by Bearman View Post
    All on Wikipedia. They weighed 600+ tons.
    URSUSMAJOR
    Queensland
    Thanks Brian and very jealous that you have had a chance to see them in real life.
    Hi Bearman and if you go to YouTube and do a search for Big Boy, you will see a heap of old “films” of the monsters.
    Also do a search for UP 3985 or UP Challenger. This is the “SMALLER” sister to the Big Boy but is still the largest active steam engine in the world.
    There are heap of present day VIDEOS of the Challenger.
    Lake Macquarie. NSW.
    They certainly are an impressive locomotive!!! Just comparing them to the 60 class Beyer Garrets that operated on NSW railways in the 1950's and 60's, the Big Boy weighs twice as much as a Garret (just under 600 tons v 265 tons) and could pull twice the load (rated 3600 tons v 1100 tons). These figures are rough. As I have mentioned before, (on other Threads) I have watched double header Garrets pull loads up the Fassifern Bank and I remember them as an impressive sight. The Big Boy would have been REALLY something.
    Here are a few of the overexposed photos of 4023. This is the best I could do with them. 4023 is in the Lauritzen Gardens, part of Kennefick Park, high on a bluff overlooking the Missouri River and the I80 bridge towards Council Bluffs. I was told the movers had great difficulty getting it in there. It came by road on a low loader. The surrounding streets are an old part of the city and quite narrow.
    These locos were built to pull heavy freight trains over the Wasatch grades between Cheyenne and Ogden. Prior to the Big Boys double heading was used on this section. Ogden was then a major rail centre with four main lines joining or crossing there and up to 200 trains per day entering and leaving Ogden yards. The expected speed in freight service was 60 mph. They were also capable of passenger service if required and a top speed of 80 mph was the requirement there.
    One almost laughs when comparing this with many Qld. Railways country services in the steam days. Average speeds not much more than 20 mph on some runs.
    URSUSMAJOR
    Bearman's Avatar
    Hay Point
    I had a look at some of the u tube vids yesterday. They certainly were an impressive steam loco. 625 tons, 132 ft long, 300psi pressure and capable of 80 MPH. Even had an auger conveyor to load the coal into the firebox. They would have been an incredible loco in their time.
    Cheers......Brian
    1985 110 V8 County
    Here is the biggest diesel loco ever used by the UP. It is also in the park at Omaha. Two x V20 EMD's. Would sound lovely under full load on a grade.
    URSUSMAJOR
    JDNSW's Avatar
    Quote Originally Posted by Ausfree View Post
    The advantage of the 60 class over engines such as this is that, OK, they had half the tractive effort, but they could run on any track in NSW. Compare for example the Victorian H class, the heaviest locomotive ever built in Australia (and lighter than the 60 class), which was only ever able to operate on the Wodonga line despite being built with the western line in mind - the necessary bridge upgrades never happened.
    Queensland
    While I would love to see one of the diesels, they were a headach for UP.
    The DDA40X, it did it’s job, but it was a very unreliable unit because it had a common crankshaft between the two engines and regularly broke the crankshaft. This meant they lost 6,600 HP every time one failed in a train.
    They are the DDA40X, is also so known as the Centennial and UP did us a good turn when they introduced the first of them back in 1969.
    The name Centennial was given to these units, to make the 100 years of UP.
    There was a special steam hauled train, run from Chicago to either LA or San Francisco. The train was originally intended to be steam hauled all the way by UP wanted to show off their new units and so a section of the trip was then diesel hauled.
    Had the train gone all the way by steam, it would set the record for being the longest steam hauled train trip in the world.
    But thanks to UP not running steam all the way, a few years later and 3801 would get the distinction of running the longest steam hauled train trip.
    Thank you Me UP.
    BTW the original name was the Union Pacific Railroad. But in the mid 1990s, because the company had diversified into so many other areas, the dropped the word Railroad from their title.
    There is another great UP steam loco still in service, the 844, and if you do a search on YouTube you may come across a gem of a trip it did in the late 90s.
    It was out on one of it’s many special excursions when a freight train ahead of it had one of it’s units fail.
    So they had the 844 assist it over the top of the grade.
    There is some spectacular video of it pushing the freight train up the grade, while still hauling it’s own HUGE passenger train.
