Results 1 to 10 of 13
Thread: Range rover classic bull bar onto D1
    Jan 2014
    Sunshine Coast
    Will it work? Found a cheap winch compatible one that i want. Said it was off a range rover classic, its also a ARB one. Cheers.
    I have tried it in the past and does not fit. The RRC is a lot squarer than the Disco although they don't look like it they are.
    This is very noticeable when you put a RRC bull bar onto a Disco. Front center is fine but gets worse as you go towards the headlights and corners.
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    Jan 2014
    Sunshine Coast
    How bad is bad? As i found a near new (looks bloody good) with light force light force lights for $450..
    Not pretty looks from far it's not the right bull bar.
    Buy it keep the lights and out it on eBay for $300.
    $150 cheap for light force lights.
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    Jan 2014
    Sunshine Coast
    Bugger. I dont care much for the lights, im just after a nice bullbar. 1.1K for a xrox one is the next option
    Melbourne - Eastern sector
    Quote Originally Posted by TriPolar View Post
    I have a rrc ARB bar on my d1 looks fine to me. Less over hang. Will post a pic later if you can see the image in my avatar.
    Mick
    I have an old ARB one for a disco. Does not have a winch bit yet but strong enough for a winch.
    I am about to put it on eBay
    Same looking as the one you are looking at on gumtree but without the winch.
    I am in Brisbane
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    May 2008
    Bundaberg Qld
    Took the bar off my old 88 RRC and it bolted straight up on my 97 Disco. (The white D1 in the pic)
    All I had to do was trim the plastic bits under the headlights.
    Jan 2014
    Sunshine Coast
    Prob the same one i already have. Its ARB and is pretty solid, the winch mounts to the front not the bottom. Just on the look out for a bargain:
    For the bar i mentioned for sale:
    Land Rover Discovery Range Rover fitting Bull Bar with Spots | Other Parts & Accessories | Gumtree Australia Brisbane North West - Milton | 1037109984
    May 2008
    Bundaberg Qld
    This is the bar when on my RRC. Don't remember the brand.
