Results 1 to 10 of 16
Thread: second gear missing
    second gear missing
    so there I was driving along and occasionally second gear became a bit of an intermittent thing,
    got to levuka for our club trip and found on a couple of tracks we couldn't get second at all, came home and pulled the top off the box, no visible problems, I did think we had a selector problem,
    drained the gearbox and a lot of teeth came out with the oil!
    so what have I done?
    box has this number 25503154 F stamped into it.
    does anyone know what box this is and what may be my problem, other than big!
    will pull the box out as time is available.
    are parts available for these gearboxes?
    Safe Travels
    harry
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    my box (151019057) seems to refuse 2nd gear if you try to select it when going even just a tad too fast.
    on occasions i have to find reverse then find 2nd when sitting at the lights as i simply can not get it to slot into second..
    no teeth in my oil thank goodness
    otherwise no noises or issues...
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Quote Originally Posted by incisor View Post
    thanks dave, and thanks for the manuals also,
    yes this box was always difficult to change down to second and first was hard to get on a down change, but I am good at that now.
    more dismantling to come....
    Safe Travels
    harry
    Gold Coast QLD
    Hey Harry, when you do pull it down, let me know so I can watch a master at work ( then I might not have so much trepidation at having a go at Ralph's gearbox).
    Ian
    1964, S2a SWB "Ralph"
    1977, S3 SWB "Smeg" (Gone)
    1996 D1 300tdi auto (Gone)
    1973 Rangie Classic (Gone)
    2012, 110 (Series 12) Puma "The Tardis"
    1962 109" Tray Back "Ernie"
    1998 D1 300tdi (Dizzy)
    2017 Kawasaki Versys 1000
    You must now cut down the tallest tree in the forest... With... A HERRING!!!!!
    Ipswich QLD.
    Parts should be available from FWD Motors at Yerongpilly, or MR Automotive, or anyone else that sells Series stuff.
    Cheers, Mick.
    1968 SIIa SWB
    1978 SIII Game SWB
    2002 130 Crew Cab HCPU
    Gold Coast QLD
    Hi Mick
    I spoke to someone from FWD last week trying to find some hood clips for the body on Ralph and the bloke told me they sent it all to the scrap merchant and wont be doing much for the series vehicles anymore.
    East-South-East Girt-By-Sea
    1.20 MB
    Quote Originally Posted by harry View Post
    IIRC the F suffix box has the sealed throwout.
    Internally anything suffix D and above are the strongest of all the series boxes (including the SIII).
    It is worth rebuilding but make sure you get compatible parts as there are a number of ratio changes between the SII and suffix A through C SIIa boxes. The Suffix D and later all have the shouldered layshaft which makes them much more reliable than the early boxes with the circlip retaining 2nd Layshaft gear.
    Diana
    of course work gets in the way of progress, but I will keep you informed of progress when I do get it out of the car.
    Safe Travels
    harry
    Gold Coast QLD
    Bloody customers, I could run a really good business if they would all bugger off and leave me alone to work on Ralph!
    ah, what a great design that sealed throwout bearing is, wouldn't find that on a jeep!
    I found second gear!
    it is on the layshaft but the layshaft has a small set of teeth which went out the sump when I drained the gearbox oil,
    the layshaft is stuffed.
    now who has a spare?
    when I get a chance I will find the part number and see if this thing is still available,
    otherwise I will be looking for another box.
    Safe Travels
    harry
