Yes have them now(255/85 R16 bighorns), you don't need a lift, I had them originally on stock suspension(sagged as 120,000k's old) and with the boost alloys which are +30mm offset(that's 30mm closer to car,0 is dead centre and negative causes the wheel to stick out further) the rear tyre would only just touch the spring mount on full flex up /other side hanging down. I've now fitted Gwyn Lewis kit along with 2in dobinsons and OME shocks and also put 4, 30mm wheel spacers from the U.K so they don't touch the mounts at full flex. These spacers are not legal in Oz but are Ok in U.K and E.U. and with 255's your tyres are just inside the standard flares so you don't need the extra cost of new ones.
The other option is to fit offset wheels, as the tyres are 255 there are plenty of options.+10mm , 0, -15mm, etc. but if 35 inch rubber is even a remote thought others recommend -25mm. Remember once you go past 0 you will need wider flares to stay legal.
One other thing , have a read about the transfer case/prop when lifting a Puma as I've read off issues with some people.
Could you stick up a few pic's of the finished def?![]()
