Thread: Defender 300tdi Air con not working
    milkshakes Guest
    Hi all,
    Recently purchased a 300tdi defender hardtop (will post on deefers when she gets a proper clean) and the air conditioning has stopped working. When i bought the truck and for the next few days it worked very well and was cold... But now it seems as if the air con clutch isn't engaging although the fan still works fine. The only thing i've checked so far are the fuses (i assume the air con fuse is with the rest infront of the gear lever) and they were all fine.
    Thoughts?
    Aug 2012
    Logan,Queensland
    300 TDI aircon fuses are in the the battery box.
    2 x fuses
    2x relays
    There is a little black box in there with about 9 wires connected to it, this is the control module.
    '95 Defender 130 Single Cab
    HS2.8 TGV Powered
    98% of all Land Rovers built are still on the road.
    The other 2% made it home.
    Cost difference between Britpart and Genuine seals: £2.04. Knowing that your brakes won't fail at any moment: Priceless.
    Jun 2007
    I have had two issues with 300 tdi air con over the years first one was the compressor clutch did not engage because the system was low on gas due to a leak on the aluminium pipe on the firewall. The second was the black control box under the passenger seat. Dwayne at MR told me that this is a common problem and the module supply is drying up. He still has a couple in stock but if you are handy with a soldering iron I would have a go at repairing it as it might be just a dry joint.
    May 2002
    Heathcote (in "The Shire")
    Even when it is fixed "working" is a relative term.
    Martyn
    My 98 Defender air con fuses and relays are with the other fuses the main fuses on the firewall
    Andrew
    1998 Landrover Defender 300Tdi 130 HCPU Expedition
    1972 Peugeot 504 Sedan - Daily Driver
    in the wild New England, NSW
    Quote Originally Posted by jboot51 View Post
    This " little black box " and is a thermo amp, OME replacement no longer available but generic item can be substituted
    May 2011
    Brisbane, Australia
    I fixed mine once by just wriggling all the connections in the battery box. With the ignition/engine off, pull out the plug (from memory), spray with WD or similar and put it back.
    Oct 2010
    Adelaide Hills
    The best thing to do with a 300TDi Deefer a/c system is turn it into an onboard air system and liberate the passenger side footwell.
    Jul 2012
    ferntree gully australia
    Hi , I put a test light at the compressor end to see if you have power , that's with It switch ,on of course , or get someone to switch you aircon on you can hear the clutch kick in .
    Oct 2011
    Adelaide
    you can see if the pulley turns even, ie, when clutch not working the centre part sits still and then turns with the clutch in.
    But the main point was to say that my 96 110 300tdi has the fuses and relay attached under the normal fuses on the firewall, but it is an aftermarket 'iceberg' fitted in 2000, although it looks a lot like the original. So if fitted later, even if an original one from a wrecker, then the fuses might be wherever the fitter chose.
