                                                31st January 2014, 09:01 AM
			Puma seat box covering
					Hi, the seat box covering on my  2010 110 is badly scuffed and detracts from the interior of  the vehicle,
 Is  this  section of the floor covering available as a spare part. I did attempt to cover the corner of the box with aluminium angle however the clearance between the  box and door card is miminal . Has a member of the forum come up with a solution to what must be a common problem.
 Thanks, Jim
                                                31st January 2014, 09:36 AM
			Moulded Matting System
					This is the following option, a very expensive one though
 Puma Rubber Matting System
 There is a very good write up from Loubery.
 The other alternative is getting some dynamat insulation type material and/or going to clarke rubber and doing something yourself......
                                                31st January 2014, 10:20 AM
                                                31st January 2014, 12:01 PM
                                                #4
					I quite like those corner protectors, but it looks like you'd have to drill the seatbox, which I'm not keen on?
 Pickles.
