Results 1 to 3 of 3
Thread: Wiring diagram for Electronic Park Brake module
    Jun 2007
    Margaret River
    Can someone help me out with a diagram for 2006 RRS, Electronic Park Brake module?
    I think I may have cooked my actuator whilst doing a park brake bedding in procedure.
    Fault mate DTC for parkbrake shows C1A00 Control Module System internal failure(overheating)
    Have checked fuses 11 and 8 in the engine bay, and 40 and 41 under glovebox. All OK
    Anyway before I start pulling out the actuator I would like to try and test it insitu.
    Jun 2007
    Margaret River
    Found a diagram here, although its for LHD
    http://www.lrservice.ru/data/277/RR_..._147226_OK.pdf
    Any advise on the module failure, would still be apreciated
    Jun 2007
    Margaret River
    Amazing. After driving around for a week using transmission park and no handbrake, all of a sudden the fault disappeared and the EPB works normally
    Now suspecting low voltage to ECU as the cause.
