G day Jock, assuming your slave is ok maybe you could try, you need a large syringe like the type used for animal jabs. Fit this to the slave bleed nipple via the same type of hose you would bleed with. Crack the nipple & try slowly pushing fluid back through the system then try normal bleed procedure.
Obviously you need the syringe to be full with no air & a very firm fit on the nipple. Might work but my experience has always needed a vacuum bleeder.
Good luck , regards Chris.
