Excellent. How much ? Link ?
 Master
						Master
						Just fitted the latest product from Nugget Stuff.
Alloy front, rear & transfer case breather manifold kit. The kit is a no hole complete kit, it mounts over two brackets on the A/C intake side of the engine bay.
Install took me about 15min to fit.
Install*
Locate the breather lines, passengers side near fire wall, cut bends of the ends of the factory airline. Install the 3 push joiners to the factory airline, cut the supplied airline into 3 equal lengths, thread the lines in the direction of the two brackets. Fit the airlines into the base of the manifold push fittings.
Remove the two bolts holding the brackets in place, position the manifold & reinstall the bolts.
Job done, close bonnet.
Kit comes with a machined aluminium manifold, 3 stainless steel 6mm airline push fittings, 3 sintered stainless steel filters, 6mm air line & 3 airline push joiners.
gone
1993 Defender 110 ute "Doris"
1996 Discovery 1
current
		Looking good.
I read today he was making a website up for his new products. Cant wait to get some extra cash so I can get some stuff.
Just like to thank Dave for making his truck available as an alternative "test" unit.
The kits are $130 plus post and are available now. Will post the link to my new web page as soon as it is finished. Hopefully Monday at the latest.
I too are interested. Looks great.
As is always the case with me, another neat solution is produced a couple of weeks after I have already addressed the problem in my typical half-arsed fashion
 Fossicker
						Fossicker
						Sorry guys this is a silly question. What is the purpose of this kit?
The breathers ina defender are raised but jusdt have a bent plastic end to stop water being sucked into the diffs during deep water crossings.
This raises them a bit more and also has a stainless steel filter on the end to give even more protection .
Very nicely done Nuggget. I like your branding, 'Nugget Stuff'
I presume they are same same for all Defender models ? eg Tdi TD5, Puma etc?
Does anyone know if there are any mods done to the breather when a maxidrive is fitted?
gone
1996 Discovery 1
current
