1st February 2014, 08:57 AM
Defender 3 Port Diff Breather Manifold
This is the only kit made specifically to fit Defenders.
Machined from high quality aluminium billet the 3 port manifold has individual ports for the front diff, rear diff and transfer case.
Supplied as an easy to fit bolt on kit, it mounts over the two brackets on the A/C intake side of the engine bay.
The kit includes the manifold block which is fitted with 3 6mm push in fittings, 3 sintered stainless steel filters, 6mm air line & 3 air push in joiners.
Kit price is $130 plus postage.
Installation directions
Install time about 15 minutes.
Locate the breather lines situated on the passenger’s side of the engine block near the fire wall.
Cut off the bent ends of the factory airline.
Install the 3 push in joiners to the factory airline.
Cut the supplied airline into 3 equal lengths, thread the lines in the direction of the two brackets.
Fit the airlines into the push in fittings on the base of the manifolds.
Remove the two bolts holding the brackets in place, position the manifold & reinstall the bolts.
Job done, close bonnet.
Go 4wd’ing.
