1st February 2014, 12:08 PM
Removing Front Lower Suspension Arms
I am not having much joy with removing the ball joint end, made a puller and with a little heat eventually got one side off. However having no luck with the other side. Anyone have a special method ?
Mine is an 02 with original arms I doubt it has ever been removed.
Peter
1st February 2014, 08:34 PM
Finally got it off, combination of pressure from puller, heat, and many hits with hammer.
When I examined the lower arms they were both in good cond, I really should have just replaced the Uppers (rear) as these were totally shot at the bush or inner end. Hope the new ones are a bit tougher.
If anyone at or near Geelong needs a puller for the ball end of the lower arms they are welcome to borrow mine. However I recommend a close check before removing as I suspect the main culprit is the upper arms when noise is heard at the front.
Peter
18th February 2016, 11:17 AM
