Results 1 to 3 of 3
Thread: Air cleaner
    Hobart, Tasmania
    Air cleaner
    Just completed a service to my 97 TDI Disco, 90,000 km's. Changed the oil - RX Super API CI4, very very good stuff!, changed the oil and fuel filters. What a game getting the filters off! God I reckon whoever put them on, and they were land rover items and done by a land rover dealer, must have used a 16" stilson to tighten them. If fitted properly the seals should be lightly oiled and the spin on filters tightened by hand only! Any way they are now hand tight and don't leak.
    When I was cleaning the air filter box, which was very very dirty, I decided to clean the attached suction pipes fitted to the forward side of the filter box. There I found an air spinner and a rubber self closing valve. The rubber self closing was absolutely full of rubbish. I wonder how many more of the same type of one way valves are completely chocker. I imagine this valve is to allow water to drain out and not allow air in?? Anyway it might stand a chance of working now. Any body else found this problem??
    All else was well.
    Shifter.
    May 2002
    Sydney, Australia
    G'day Shifter,
    I found that the oil filter done by hand was enough - just remember to tighten again once warm.
    Also when taking off the oil filter - place a plastic bag over the filter and unscrew from underneath the car - bag catches most of the oil spills.
    Hope this helps,
    LRH.
    Disco 4 SDV6 Auto
    Disco 4 SDV8 Dual Cab Project
    Disco 2 M57 Extra Cab Project
    Foton Tunland Cummins ISF
    Disco 1 3 door 4.6 V8 Auto
    RRC V8 Auto "Classic" Softdash
    RRC 300 TDI Auto
    Disco 1 TD5 Auto Buggy
    Disco 1 300 Tdi Auto Ute
    SAME Explorer 70HP 4x4 Tractor plus Nell Loader
    Subaru GDA WRX
    Triumph Bonneville SE
    Yamaha TTR250
    May 2003
    On The Road
    Yep shifter,, the good thing about doing your own servicing,,
    you (should) always be able to undo the filter by hand,,, [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]
