Results 1 to 10 of 21
Thread: To much oil pressure for tubro?
    Feb 2009
    Mt Isa Qld
    Hey all,
    So finally got turbo and exhaust sorted. Took it for a run, and it was blowing alot of smoke! Pulled the exhaust off and found alot of oil, there did look to be much in the manifold when I peeked through the wastegate. Its a T25 turbo I got off eBay which I put a rebuild kit through. Turbo oil is fed from side of dual filters, and drain line drains into the tappet cover.
    No the drain hose does have a small kink in it, could this cause the problem?
    Does anyone run oil restrictor to there turbo? Could there be to much pressure?
    Hopefully someone can help
    Sean
    Geelong, VIC
    I'd put money on it being a drain issue. Particularly if the drain hose is kinked.
    I think the standard banjo bolt for a T25 journal bearing turbo has a 1.6mm hole in it.
    Of the "my new turbo is ****ing out oil" threads on here I can't recall any that turned out to be pressure related. IIRC all were drain issues.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Feb 2009
    Mt Isa Qld
    Thanks for the quick reply. I'll get that fixed and see how it goes. Will I need to put in seals through turbo?
    Oct 2012
    FNQ
    Tappet cover ? the drain should be as vertical as possible low down
    AM
    Kiwiland
    Quote Originally Posted by HotWired View Post
    No seals needed. But it may take a few miles to get the oil out the turbo once you fix the drain.
    NSW SW Slopes
    Chinese copies often don't have the inbuilt oil supply restrictor that Garrets have. Banjo bolts with the correct size hole to restrict the oil supply can be readily bought.
    Edit: My son thought his new turbo was a dud until he discovered the lack of a restrictor in the replacement.
    NSW SW Slopes
    Quote Originally Posted by Ancient Mariner View Post
    and never uphill!
    Oct 2012
    FNQ
    Maybe a Tubro should drain into a Tub( Sorry)
    Tappets run on the cam and the tappet covers for a 4BD1 are on the side of the block below the turbo.
    Ideally the turbo drain would be lower, but .....
    Aussie Expat in NZ
    FWIW I observed my turbo leaking a tiny bit of oil when I first started up (half a tea-spoon or so) but it disappeared quickly (seconds). My assumption is that before thermal expansion the shaft clearances allow a small amount to leak.
    I was a little concerned when I first started it up after fitting but after checking everything several times and then running it sans-exhaust I found out that it was fine.
    Regardless, the turbo drain should be as close to vertical as possible, of the correct size and without sharp bends or restrictions..
