Thread: My VIN
    Palmerston NT
    My VIN
    Hi folks... just looking up what the characters in my VIN mean but it seems it doesn't quite line up with what it says in an online workshop manual I found...
    My VIN is SALLDCH572V84938b
    So from what I understand is;
    SAL = world manufacturer
    LD = Landrover Defender
    H/V/K = 110/90/130 (but I have a C here?)
    M/A/B/E/F/H = H for High Capacity Pickup sounds right
    8 = TD5 - but I have a 5 here?
    7 = RH drive
    Not sure what the rest means...
    Its a 2003 130.. can anyone enlighten me? The compliance plate does say "Country of Origin" - South Africa also... is that common?
    sheerluck Guest
    SAL Manufacturer code: Land Rover
    LD Model: Defender (for early models: Ninety, or One Ten)
    C Wheel base: 130 inch, Extra Heavy Duty (XD)
    H Body type: High-capacity pickup (HCPU)
    5 Engine type: 2.5 litre Td5 (EU5 spec)
    7 Steering and transmission: Right-hand drive (RHD), 5-speed manual (LT85, LT77, LT77S, R380 or other)
    2 Model year: 2002
    V Assembly location: Blackheath, Cape Town, South Africa, for 147-specification
    84938B Serial number
    sheerluck Guest
    Logan Village area S.E. QLD
    All these years use the conventional Vehicle Identification Number (VIN)
    Digits 1 Geographic Region: S = Europe
    2 Country: A = United Kingdom
    3 Manufacturer: L = British Leyland/Land Rover
    4,5 (model) LB = Series III, Stage I, Lightweight
    LD = 90 & 110, later Defender
    LH = Range Rover (mk I) (Classic)
    LJ = Discovery
    LN = Freelander
    LP = Range Rover (mk II)
    LT = Discovery, Series II
    6 (wheelbase) A = 88" & Freelander, & 100" for RR mk I
    C = 109" and 1 ton
    G = 100"
    H = 110" & 147"
    K = 127"
    M = Special
    R = 110"
    S = Military 110"
    V = 92.3"
    7 (body type) A = Truck Cab, Soft Top or Hard Top (Utility body)
    B = 3 door Station Wagon, or Freelander 5 door hardtop
    E = 2 door Crew Cab
    F = 4 door Crew Cab
    H = High Capacity pick-up (Some had an A instead of the H)
    M = 5 door Station Wagon & 7 Door SW
    R = Monteverdi Range Rover
    8 (engine) B = 2.5l, 4 cylinder, Turbo diesel
    C = 2.5l, 4 cylinder, diesel
    D = 2.5l, 4 cylinder, petrol
    F = 200 Tdi & 300 Tdi (2.5 Liter, 4 cylinder, Turbor Diesels)
    G = 2.25l diesel & Freelander V6
    H = 2.25l petrol
    M = 3.9 liter V8 (injection)
    P = 2.6l 6 cylinder, petrol
    V = 3.5l V8 petrol (carburettor)
    Y = 2 liter T16 petrol
    Z = 3.9 liter Izuzu diesel
    3= 4.2 V8 petrol (injection)
    8 = Td5
    9 (steering/transmission) 1 = RHD, 4 speed
    2 = LHD, 4 speed
    3 = RHD, automatic
    4 = LHD, automatic
    5 = RHD, 4 speed & overdrive
    6 = LHD, 4 speed & overdrive
    7 = RHD, 5 speed
    8 = LHD, 5 speed
    10 (model variant/model year?) A = up to 1983-1984
    B = 1985-1987
    E = 1988
    F = 1989
    G = 1990
    H = 1991
    J = 1992
    K = 1993
    L = 1994
    M = 1995
    N = 1996
    ? = 1997
    ? = 1998
    W = 1999
    ? = 2000
    1 = 2001
    2 = 2002
    11 (assembly location) A = Solihull
    F = CKD
    V = South Africa
    12-17 (serial number)
    Mrs hh
    Series Landy Rescue
    Our FB Page..
    Quote Originally Posted by djambalawa View Post
    7 = RH drive
    Interesting it says yours is a 2002 model, and yes South Africa is common. Are you sure the 8th number is correct? Are you reading off the windscreen plate, you are right is should 8. OK I have checked ours and we have a 5 also. and ours is definitely a Td5 so maybe the info is incorrect. The Clifton one is more correct.
    http://www.lrfaq.org/FAQ.3.LRevents.html
    Mrs hh
    Series Landy Rescue
    Our FB Page..
    Palmerston NT
    Thanks all - I thought I had an '03 so good to know what year it is.. hmm might have had more chance of a Salisbury diff with a '02? Ah well.. it doesn't have one
    Mar 2010
    Mudgee-ish
    Quote Originally Posted by The ho har's View Post
    B = 1985-1987
    E = 1988
    F = 1989
    G = 1990
    H = 1991
    J = 1992
    K = 1993
    L = 1994
    M = 1995
    N = 1996
    ? = 1997
    ? = 1998
    W = 1999
    Fascinating. I have a 1995 130 Defender. At position 10 of my VIN I should have an M, but I have a T. What does that mean?
    Just looked up the Clifton, should have done that first, T is model year 1996 (I have a 1996 compliance plate and 1995 manufacture date).
    Palmerston NT
    Just had another look at mine and it is dated 06/03 so yeah dunno why the VIN would say 2002.
    sheerluck Guest
    Is that 06/03 the compliance date or the build date? Don't forget that all three of those dates/years can be different.
    My understanding is that that model year is which year's 'equipment list', for want of a better term, that the vehicle belongs to. So if there are no updates or changes to a vehicle's spec from one year to the next, then it can still show the previous calendar year's model letter.
    It would be the compliance date, so 2002 is the build date Land Rover's years go from end August. Simular to a calendar year. My 1951 series 1 was sold 8/12/1950 in Tamworth
    Mrs hh
    Series Landy Rescue
    Our FB Page..
