Results 1 to 3 of 3
Thread: 200TDI Cam Followers
    Mar 2011
    Hey all,
    I'm in the process of reassembling my 200Tdi and was wondering if I need to replace the cam followers.
    They look to be in great condition but I didn't mark which assy came out of where and which way around they were. The manual mentions that if they're being reused to mark them but is it critical?
    Alex
    AlexTurner
    Jul 2012
    Gaborone, Botswana
    Yes, because the followers will have "setaed themselves in" to the camshaft lobes, so if you say put them in the wrong slot or flip them 180 you'll just wear them more quickly. Depending upon that wear you may find you need to replace them "soonish", so you may as well bite the bullet and replace them now. You may also want to consider replacing the camshaft (and cam bearings and... well, where do you stop...).
    Nov 2008
    Bruthen, Eastern Vic.
    They are roller followers so they would probably be more tolerant of being replaced in different locations.
    If you fit new followers you should fit a new camshaft anyway.
    I would just refit them with moly grease on the cams and see how it goes.
    Terry
    80 109" 2.6 P ex Army GS, saved from the scrappie.
    95 300tdi 130 Single cab tray.
    2010 Guzzi 750
