Results 1 to 4 of 4
Thread: Perentie Rear Axles
    Dec 2008
    Perentie Rear Axles
    Hi
    I have a new set of Heavy duty Maxi Dive (Hi-TOUGH) axles for a 130 defender.
    Would they fit in my RFSV fitted with disk brakes?
    Any help appreciated
    regards
    Andrew
    Bearman's Avatar
    Hay Point
    I seem to recall that the MD Defender axle has shorter splines on the drive flange end than a County MD one but easy way to check is remove one from the RFSV and compare it to the Defa one. The County has a thicker (more spline length = less wear) drive flange than the Defender. Should have mentioned, Perentie and County axles/drive flanges are the same item on the rear axle.
    Cheers......Brian
    1985 110 V8 County
    Feb 2005
    Pretty sure I ordered the longer axles (I assume county) for my 300tdi and yes the splines for the drive flange are longer requiring a wider drive flange to suit......not sure if the makes sense
    I reckon they will fit you will just have to work out which drive flanges to order
    Dec 2008
    Thanks I'll pull them on the weekend and compare
