I've read of two other p38's with HID on the driving lights, that have drawn the main power supply for the Ballast resistors through the BECM. Both worked for a while, and then they stopped working.
My understanding is that the Ballast resistors have a very high unrush current, that (IMO) is to much in the long term for the FET relays inthe BECM. Looking up the part numbers of these relays a few years ago they don't have a very high current rating at all.
If your auto elec. triggered the ballast resistors through a relay from the battery then I can't imagine there'd any effect on any of the cars electrics (unless you've a bad battery / earths etc...)
I was looking at putting HID on the driving lights only; but when hearing that someone on this forum had trouble in the same way that i'd heard of before on rangerovers.net i decided against it.
Hope this helps.
