My previous reply was lost in the crash, but I'd pull the axles out first, and just nip it up until you start to feel a slight increase in rotational resistance. It should be happy like that until you can get it sorted properly.
The crush spacer is behind the front pinion bearing, and can be replaced without taking the pinion out. It's bloody tight to start the crush, and I doubt you'd do it lying under the vehicle. I did mine with the entire diff out on trestles and it was still a bit of a struggle.
Any diff place can replace the pinion bearings for you - it doesn't have to be a LR mechanic.
Its also pretty do-able yourself if you've got a press to fit the rear (larger) pinion bearing, and a DTI to check the backlash etc.
Steve
1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
1988 120 with rust and potential
1999 300tdi 130 single cab - "stock as bro"
2003 D2a Td5 - the boss's daily drive
