Results 1 to 10 of 11
Thread: Series 2A 6 cylinder water pump O ring
    alanw is offline Fossicker Silver Subscriber
    Mar 2010
    NSW
    Hello,
    A question re 1967 Series 2A 6 cylinder.
    Does anyone know the dimensions of the O ring between the top of the water pump and the bypass fitting under the thermostat housing?
    Thks in advance
    alanw
    Quote Originally Posted by alanw View Post
    Try Jim, send a PM to russellrovers as he could supply one or at least may be able to give you the dimensions.
    Narre Warren South
    Just found one in an old gasket set. 1/4" cord diameter, 1" OD (so about 1/2" ID)
    There is a lot of flash on the mould line so it looks like low volume production rather than from an O-ring supplier.
    Hope this helps.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Mar 2009
    Royalla NSW
    Scott's old rubber do them as well. Please note that there is a cooper ring that is fitted inside the o-ring. Look at the series 1 water pump bits on the Dingocroft website.
    Regards.
    Nov 2008
    Quote Originally Posted by toad View Post
    Regards.
    That's interesting, and might explain why mine leaks. I knew the Series 1 had the copper 'collar' but not the 6. Would it be the same dimensions on both engines?
    Roger
    Mar 2009
    Royalla NSW
    I will check my parts books and let you know. A bit of RTV rubber outside the o-ring never hurt as well before you bolt the thermostat housing or water pump back on!
    Mar 2009
    Royalla NSW
    2.6 water pump
    You need an RTC1975 o-ring and a 9197 washer (ring). That should help fix things!
    Nov 2008
    Thanks toad
    Narre Warren South
    My parts books show a split bush (metal) part number 564164 up to suffix B engines. This pushes into the water pump and sticks out for the O-ring to locate on. Not something you might normally replace/remove.
    No need for a copper ring fitted inside the O-ring.
    A later picture shows a spigot on the pump body but does not list p/n 564164 as a separate item
    Picture below is the motor from my FFR, you can see the O-ring sitting on the spigot on the pump (you can just see a split so it must be p/n 564164)
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Nov 2008
    Thanks Colin - water pump in your picture looks same as mine, except the spigot/bush on mine seems to be damaged, which may be letting water escape. Not enough to be noticeable in the tank, but always a brown stain from that joint. Will search the usual suppliers tonsee if anyone carries that part.
    Thanks again
    Roger
