Results 1 to 10 of 17
Thread: Got some old 130 springs laying around?
    Feb 2011
    Traveling Aus
    Long shot but does anyone in Melbourne have a old set of rear springs for a 130 laying about I could buy/borrow?
    Hit a snag on the weekend in Tas and some along the line I have ended up with a broken coil
    Long story short, they are custom springs and to get a new one made I need to take out my good remaining coil to be load tested so a new one can be made.
    I need something to whack in there while the new coil is made as I can't afford to have the car off the road with us traveling around Australia and all.
    It never really crossed my mind that one of my coils would break so didn't even think to find out what rate they are when they were made... feel pretty silly now though...
    Or does anyone have any idea's on how to avoid costly and annoying downtime?
    We get back into Melbourne next Monday the 24th.
    for the moment we are making do with driving on a broken coil (broke at the very fist twist of the coil if that makes sense)
    Ben
    Scarborough, QLD
    I've got some, but up in Qld unfortunately
    Feb 2011
    Traveling Aus
    Haha cheers for the thought anyway.
    Can't believe I didn't take the time to get the spring makers to tell me what rate they ended up twisting them to.
    Rookie mistake
    Geelong, VIC
    I've got a few different 110 rear springs here that you'd be welcome to borrow if they were any use. Heaviest known ones are about 320lb/in though, so not sure if they are heavy enough for you. Might be some heavier but I'd have to look.
    Have you tried contacting whoever made the springs for you originally. They may well have records of exactly what they supplied you.
    How about working out the spring rate yourself. I don't recall the formula, but its based on wire diameter and number of coils (assuming they aren't progressive springs). Or do you have a water tank or a few jerries that you can empty/fill and measure the spring compression?
    I assume you're getting a new pair made, and not just replacing the one spring? If you've broken one I'd be concerned about the other one also breaking as they would have both had the same manufacturing processes and heat treatment etc
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    May 2003
    On The Road
    (bump) which way do 130 springs sit?
    across like the axle?
    or front to back?
    NSW far north coast
    TD5 and back 110 and 130 outer rear springs are the same rate (330lb)
    Inners IIRC are 140lb.
    you may be able to calculate the spring rate with the one still in the car. That would assume it is sitting fairly level and even weight on both sides???
    Spring rate: K = (G x Dw^4) / (8 x Dm^3 x Na)
    K is spring rate in N/mm, x 5.711 to get lb/in
    G is shear moduls, or modulus of ridigity = 79340
    Dw is dia of wire of the coil - NO PAINT
    Dm is the mean diameter of coil (OD - Dw) or (ID + Dw)
    Na is the active number of coils
    / is divide
    ^ is "to the power of" - ^4 is the power of 4
    I wrote this out from a thread Bush65 posted in a little while back so I may have something wrong?
    Mandurah WA
    Benz,I have a set of 130 rear springs[inner &outers] you are welcome to pick up for free.PM me.
    Feb 2011
    Traveling Aus
    Unfortunately they guys I had make the springs don't keep records on their custom springs and at this point not really offering any help to keep my on the road and get a new set made.
    They said the best option would be to take the car off the road while they check the rate and get new ones made but down time for me would be a major hassle and quite costly.
    They said they could check the rate and then re-install the broken springs if I wanted but it would cost a pretty penny as I would be charged for the whole time the car was on the hoist while they run the springs around to the spring makers for them to be tested.
    I asked if they had anything laying around they could stick in there to get me by but they suggested this would be unsafe and they weren't prepared to do that.
    at this point it seems it would be easier to sort it out myself...
    Hence why I'm looking for something to stick in there while new springs are made.
    Eddy you have a PM (but it sounds like your in Mandurah W.A.)
    SteveG, 110 springs might get me by if they are uprated as I can unload the car while the new ones are made.
    I only need the car to get around the place while we volunteer at Edgar's Mission north of Melbourne. It won't matter too much if it sits a bit ass down.
    The custom ones were only made to get the 130 back to standard height when loaded anyway.
    If 110 springs and the outer 130 springs are the same rate on td5's what rate is standard? A quick search showed 270 lbs but that was quoted for a 95 defender. would 320lbs springs get me by if unloaded?
    as for measuring the rate of the springs while still in the car, I had no idea this was possible. Why didn't the guys who sell them (I'm led to believe they get quite alot of custom springs made) suggest that as an option? they did go on about them being unique in construction or something and pushing the limits of the material they are made from.
    I certainly wouldn't be able to do that myself, well not sure I would trust myself to do it right.
    hmm I'm sure I will work it out eventually.
    Geelong, VIC
    If you're unloaded then 320lb springs should be fine. They worked OK for me in a 110 at around 3T, but would bottom out too easily on rough tracks. Should be fine if you are driving around with not much onboard on normal roads/tracks.
    Why do you need custom springs in the first place? Surely between genuine and the larger aftermarkets such as Dobinsons and Kings etc there would be something that would suit your needs?
    I'll try and have a look tonight at what I've actually got in the shed.
    Steve
