Thread: D3 wheel nuts???
    Jan 2010
    tom price the pilbra, west aust
    D3 wheel nuts???
    How do they work? Do they have a silver cover
    That slips when they are tight enough or is that just a cover
    And the actual nut to tighten is underneath ?
    Dec 2009
    Ranelagh, Tasmania
    The nuts have a cover, however it is not removable (unless they are damaged). If you use an air tool it will likely damage them over time and you will have trouble fitting the socket over them.
    I changed mine to solid nuts and now I can use an air tool without damaging them.
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
    Jan 2010
    Yeh but if the cover slips while aim doing them
    Up by hand, how do I know they are tight enough or are they
    Ment to slip once tight enough?
    Dec 2011
    Only use a 6 point socket a 12 point will damage them.
    Recommended torque from memory is about 120NM.
    Barryp
    Dec 2011
    Forrestfield WA
    Quote Originally Posted by ade View Post
    The cover won't slip when doing them up with a spanner. They should be the shape of the nut and hence impossible to slip when tightening by hand also.
    If they are slipping they must be out of shape and I would think that the correct sized spanner won't fit either. The correct size is 22mm.
    Bob
    Jul 2013
    Definitely make sure if you go to a tyre place you tell them not to use a double hex socket (12point). A certain big name tyre place buggerd a few of mine just the other day by doing this, even though I told them not to.
    sheerluck Guest
    Quote Originally Posted by Crimdog View Post
    Need a new set? I've got a set of 20 in the markets.
    Jan 2008
    Lysterfield, VIC
    Don't forget one of them could be the lock nut, that cap is designed to come off.
    Dave.
    Hi.
    96 Disco 1 V8.
    99 Disco 2 TD5.
    LROCV.
    Not on a Disco 3, Disco 4, RR Sport Or Any Vogues.
    Only Disco 2, Defender & Early Freelander.
    Adelaide Hills
    Quote Originally Posted by BobD View Post
    Bob
    Always carry a 23mm socket as well. It will fit over a damaged nut where a 22mm will not. Been there
