Results 1 to 2 of 2
Thread: Peel gauge
    jordo84 Guest
    Peel gauge
    Broke my old gauge/switch and my local gas man ordered me 6 pin peel one, now my old girl will only run on petrol and will only run for a couple of seconds on LPG, my old switch had only five pins?
    Crafers West South Australia
    If the switch (which you didn't identify by part number) has a RPM input then one of the wires is connected wrong. There should be a connector that is wired to the ignition coil negative so the switch will allow gas to flow only when the engine is actually firing and stops after 1-2 secs if the ignition goes off.
    Look here for guidance.
