Results 1 to 10 of 17
Thread: AM Radio Receiver Options for D2a?
    Oct 2011
    Fremantle WA
    I know this was discussed a couple of years ago, but it's time to see if there has been any progress.
    I have a new good quality Pioneer head unit professionally fitted, but like the original LR version (now with Bradtot) and my version 1 Pioneer, all had/have crappy AM reception - I'm an old fart who likes 1080 AM in Perth, and in some/many areas can't receive the N & S coastal FM version option. Even ABC 720 AM in the bush can be problematic. Driving along the freeway next to the electric train line is an absolute joke.
    Is it the radios of today or?? I never had these problems with my original equipment GMH in my EH, but then again we didn't have microwaves, mobiles etc then either.
    I have replaced the original rear window arial with an on bull bar version, but reception in my area (limestone and ??) is still marginal at best.
    I'm seriously thinking of adding a second AM only system if that is possible.
    Comments/advice?
    Aussie Expat in NZ
    Should only be the aerial..
    Williams West Aust
    Gavin
    Look on Ebay,there are a range of cheap in-line signal amplifiers that may help.
    My D2 has an Alpine head unit,older as it still has a cassette,no AM issues at all.
    Eurovox made the best AM units in the past specificaly for Aussie cars.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Gosnells
    I'll confess to preferring the AM stations in general, and ABC/regionals in particular
    A decent aerial is much better than an add-on in-line RF amplifier, which is just as good as amplifying noise as it is signal.
    I feel your pain, the piece of (expensive?) rubbish in my softdash Classic is hopeless on AM. - Either too little signal-quiet- ...and noisy, or, press the "DX" (long distance) button and the front end overloads and it's loud AND distorted.
    Mine has the radio aerial on one of the rear windows, with an in-line amplifier up in the roof lining, AFAIK. US models had them on both rear windows.
    Never tried it in the bush, but if the Perth-Mandurah freeway run is any indication, then my 100 year old SONY AM/FM Walkman is just a good.
    Or bad...
    PS, as far as Perth is concerned, I wonder if the AM transmitter power has been reduced.... or moved to a less effective location.
    Avoca Beach
    All Japanese/Chinese/European radios are the same on AM.
    That is because they have the opposite problem to Australia.
    They have lots of AM stations near each other and cross talk becomes a real problem IE a harmonic of another station blowing through the signal.
    It is expensive to improve selectivity so most radio manufacturers reduce sensitivity so that crosstalk is not such a problem and they can use cheaper components. Most AM radios AFAIR (from when I was ICE manager at Sanyo about 30 years ago!) are about 20Mv at 1 metre whereas some of the old AM discrete radios were 10Mv and the early Eurovox were 10Mv
    Nowadays most tuners are probably the same IC so the idea of them making a high selectivity radio for Australia is just not possible.
    All you can do is get the biggest antenna you can practically fit with low loss cable. Mobile one do one for FM but it also helps AM. However it is helically wound so cannot be retracted.
    Regards Philip A
    Gosnells
    Or fit a very old car radio and poke it's signal into one of your head-unit's AUX inputs...
    - You know, one of those dinosaurs where the inductive tuning mechanism is bigger than your whole (modern) 'entertainment unit'
    Oct 2011
    Fremantle WA
    Quote Originally Posted by superquag View Post
    I love it when you talk dirty - now to find out what it all means!!
    Aug 2012
    Tewantin (NOOSA area)
    Hi
    If you are still looking this is what you need to install. Interstate truckies use them almost exclusively. ...................or so I was told. Mine works a treat.
    AudioXtra - Axis, Blaupunkt, Dynamat, Uniden, Vertex Wholesaler - SW2
    The lead is, if I recall the correct impedance (90ohm) for AM. Everything else out there is 70-75 ohm and set up for FM.
    You can also get the short whip for around town.
    Oct 2011
    Fremantle WA
    Thanks Rick - looks good and am following up.
    Aussie Expat in NZ
    Axis antenne are made in Cessnock, NSW too ... for people who care about that sort of thing
