Results 1 to 4 of 4
Thread: Td5 Defender Wiring Schematic
    TBA
    Gday
    Does anyone have a copy of the Td5 wiring schematic? I need to wire in an electronic speedo and air conditioning unit to my County
    Jock
    Jan 2009
    Seymour, Victoria.
    Go to a site called "http://www.landroverweb.com/landrover/" and click on the PDF manuals
    You will find what you want in their.
    Nino.
    BigBlackDog Guest
    What he said: pdf Land Rover Manuals | Landroverweb.com
    The file is defender 2002 wiring diagram. Works well for my 95 truck!
    Geelong, VIC
    There's also some good tutorials around on the UK forums for fitting the Td5 speedo to older Defenders. From memory you need to use the defender transducer not the disco one as they have different pulse frequencies.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
