My last car, a Pajero had exactly the same sort of symptoms when I used to tow a 6.5 metre boat. It ended up being the a combination of things in the cooling system and I eventually had a top radiator hose blow - would you believe 2 days before I had the car booked in for this issue to be looked at. It came on gradually over time and I had no problems when I didn't tow a heavy load up steep hills/mountains. Ended up needing a new radiator, water pump and hose of course. The mechanics, local guys who I trust implicitly, had a devil of a time diagnosing the water pump. The impeller was actually slipping on the drive shaft and this caused fluctuating temperatures all over the engine. They used a sensor of some sort to check the temp in various parts of the engine to make sure it was ok. As you can imagine it wasn't cheap as the repairs meant taking the front of the car off basically.
My suggestion would be to get the cooling system checked out by someone you trust sooner rather than later. I was lucky not to have blown the engine as the gauge was misleading - something to do with water being pumped around and covering the temp sensor and then you run on empty without realising. One final thing. Apparently modern hoses don't show signs of failure like the old rubber ones did. I had the bottom hose go 2 months later. They said that they don't replace parts if the are not faulty but with hoses they look ok until they fail. In hindsight, if I had known that I would have told them to replace all the hoses.
Martin
					 D4  2.7litre
D4  2.7litre
