25th February 2014, 10:26 AM
March Very Special Offers
March offers, limited stock.
575601-B 3.5LT CARBI RANGE ROVER FUEL TANK $600
68-FWA + 50MM FLEXI FLARES SET - DEFENDER 90/110 $500
BHB700051-B DEFENDER TAIL GATE HINGE - AFTERMARKET $80.00
BTR9548 RANGE ROVER P38 PLENIUM FILTER - GENUINE $20.00
CAS500070PCL-A FRONT MUDFLAP KIT - RANGE ROVER SPORT - OEM $160.00
CAT500070PMA-A L322 RANGE ROVER REAR MUDFLAP KIT - OEM $130.00
CAT500120PCL-A RANGE ROVER SPORT REAR MUD FLAP SET – OEM $170.00
DA2369 LAND ROVER SERIES 2A CLUTCH KIT $165.00
DA5502 DEFENDER H/D STEERING ARM SET $250.00
DA5503 RANGE ROVER/DISCO 1 >TA H/D STEERING ARM SET $300.00
DA5504 DISCO 1 TA> H/D STEERING ARM SET $250.00
DA5509 DISCO 2 H/D STEERING ARM SET $265.00
DA5630 DEFENDER FRONT SEAT RE-TRIM KIT – GREY VYNIL $200.00
DPC000150PMA DISCO 2 FRONT BUMPER ASSM 03-> - GENUINE $890.00
ERR7393 LH EXHAUST MANIFOLD ASSEMBLY – D1 & D2 V8 $210.00
ESR1445-A 300TDI DISCO & 3.9 V8 AIR FILTER – COOPER $15.00
ESR4238M-A DISCO 2 - DEF TD5 AIR FILTER – MANN $15.00
HLS103 IGNITION LEAD SET - D2 V8 & RANGE ROVER XA-> $55.00
IAB5000290 GENUINE TRANSFER CASE - DEFENDER 07> - 1.2 - EXCHANGE $2150.00
LDF500180-A 300Tdi CYLINDER HEAD - AMC WITHOUT VALVES $980.00
LEF500040-A 300Tdi CRANKSHAFT – GENUINE $1070.00
LR002773-A FREELANDER 2 SIDE STEPS – OEM $640.00
LR003322-A FREELANDER 2 MUDFLAP KIT - OEM $120.00
LR004286-A GARRET TURBOCHARGER - TDV6 2.7L DISCO 3 & 4 $2871.00
LR009324-A TDV6 WATER PUMP – OEM $170.00
25th February 2014, 10:29 AM
More offers Page Two
LR016655-A TDV6 FRONT TIMING BELT KIT - DAYCO $300.00
LVB500030-A CYLINDER HEAD GASKET 3.9-4.6 - ELRING $30.00
LYS-D3WM DISCREET WHINCH MOUNT D3/4 $630.00
LYS-DEFLB LANDY SPARES - DEFENDER ROOF LIGHT BAR $150.00
LYS-DISLB LANDY SPARES - DISCOVERY ROOF LIGHT BAR $150.00
LYSDSG2 DISCO 2 STEERING GUARD – STEEL $180.00
LYSSG90 DEFENDER STEERING GUARD – STEEL $180.00
LYS-TWABD1 DISCOVERY 1 TUBULAR WINCH BAR WITH “A” BAR $880.00
PCC000100-A FREELANDER 2.0TCIE RADIATOR- OEM $280.00
PCC000110-A FREELANDER 1.8LT RADIATOR – OEM $650.00
PHE100460-A ROVER 75 AIR FILTER - MANN $20.00
PMF000050-A TURBO CHARCHRGER - RANGE ROVER TD6 - GARRET $3200.00
RKB101200-A DISCO 2 REAR SUSPENSION AIR BAG – CONTITEC $320.00
SFP000120M-B FRONT BRAKE PADS – P38 & D2 - MINTEX $55.00
SFP000270M-B FRONT BRAKE PADS - DEFENDER 90" - MINTEX $22.00
SFP100360L-A FREELANDER FRONT BRAKE PADS > 01 - LOCKHEED $89.00
SFP100470M-B DISCO 2 AND RANGE ROVER P38 REAR BRAKE PADS - MINTEX $70.00
SFP500100L-A FREELANDER 01> FRONT BRAKE PAD SET - LOCKHEED $65.00
SFS000030-A FREELANDER REAR BRAKE SHOE SET $45.00
STC1675 GENUINE 300Tdi SHORT ENGINE $5400.00
STC2880-B HANDBRAKE SHOES - 4SPEED - RANGE ROVER UP TO 1985 $75.00
STC2950 DEFENDER 83-86 110/130 FRONT BRAKE PADS - GENUINE $75.00
STC4082-A V8 VRS KIT - 3.9 - 4.6 - ELRING $180.00
STC4096LDR 300TDI TIMING BELT KIT WITH SEALS - OEM $190.00
STC4561-A FREELANDER TD4 FLYWHEEL - OEM $1400.00
25th February 2014, 10:30 AM
And Page 3
STC8363-A LAND ROVER SERIES 3 CLUTCH KIT $170.00
STC9186-B FRONT BRAKE PAD – EARY RANGE ROVER CLASSIC $45.00
STC9187L-A DISCO 1 - FRONT BRAKE PADS - LOCKHEED $78.00
TAG500043 FRONT DIFF - R/R L322 4.2 & 4.4 AJ - NEW - GENUINE $1780.00
TF807 TERRAFIRMA ROCK & TREE SLIDERS D1 5DR $1075.00
TF810 TERRAFIRMA ROCK & TREE SLIDERS 110 DEF $645.00
TF814 TERRAFIRMA 130 DEFENDER ROCK & TREE SLIDERS 130 DEF $920.00
TRC103160E FACTORY RECO R380 GEARBOX - 56A SUFFIX L - EXCHANGE $2400.00
URB500070-A FREELANDER TD4 CLUTCH KIT - OEM $310.00
WFX000260 DEFENDER 110" TD5 FUEL PUMP - GENUINE $1100.00
25th February 2014, 09:19 PM
#4
Was hoping to see a very special March price delivered to WA for a full length Defender 110 Hannibal roof rack
