Hi Marty and there is no problem charging your battery “in situ”.
To set up to do this, connect the positive power supply lead to the cranking battery's Positive terminal.
The negative power supply lead must NOT connect to the cranking battery’s negative terminal.
The negative power supply lead must be connected to a earth point, away from the cranking battery.
If you have a look in your engine bay, at the inner guard, just in front of the cranking battery compartment, you will see two 6M studs fixed to the guard.
You can safely use these as the negative connection point.
BTW anti zap devices are nothing more than snake oil, don’t bother with them.
