4th March 2014, 07:49 PM
Opinion needed
I have this engine which I have had for a while, I decided yesterday to check the compression, No 1 105psi, No2 50psi, No3 30psi, No4 95psi.
I took the head off suspecting a blown head gasket and I was right
no wonder the compression was down
now all the bores have a ridge I guess at around 5<>10thou,
the pistons have no movement at TDC, so do I just remove the ridge and re-ring the pistons or do I get a quote and have it bored .040 O/size and source pistons from the UK??.
Now this engine is only going to be used periodically (historic rego) and wont be doing highway speeds for long distances, what should I do, cheers Dennis
ps I know the head gasket has been fitted wrong way about as well,,. the pistons are std size as there are no other marks other than the numeral 1 B X, no other marks are on the crown of the pistons.
4th March 2014, 07:55 PM
Give it a light hone, new rings and drive it!
4th March 2014, 08:07 PM
Its all up to your wallet and how honest you are being about how far you want to go....
If you are likely to do less that 10000 miles in the next 5 years I would re ring it,
It will be the condition of the crank and bearings that will cause you the most problems.
7th March 2014, 08:32 PM
#4
Well this afternoon I loaded the engine into one of my No5 trailers
headed off to a mates place (mechanic old school L/R), with the help of some pneumatic tools, it was down to it's bare bones in no time
and all is good, I do not need to have the engine re-bored as I first thought, the pistons are fine, all the bottom end bearings are perfect. So on the phone and place an order for what I need from the UK (Blanchards), hopefully all parts will be here end of next week.
We had to take the leader of the pack with us
as she is terrified of storms, and the BOM predicted something this afternoon, anyway that's been part of my day, cheers Dennis
9th March 2014, 04:43 PM
#5
Continuing with this engine, whilst waiting for the parts to arrive from the UK, I have grit blasted and repainted a few of the engine ancillary parts just to brighten them up a little
I found my new copper head gasket and a few others that I will need, maybe sometime through the week, I will get time to dis-assemble the head, anyway cheers Dennis
ps when this goes together, I will have a 83 Mod Land Rover 5 main bearing diesel engine spare
9th March 2014, 05:12 PM
#6
Like your smalls on the line!!!
LOL
10th March 2014, 06:58 PM
#7
No Muddy, most of what you can see belongs to the Poodle Patrol, they had been washed and so had the face washers, towels & bed covers from their respective beds, cheers mate Dennis
10th March 2014, 09:02 PM
#8
18th March 2014, 06:48 PM
#9
While waiting for my engine well the big bulky thing LOL, I have been grit blasting some smaller parts, etch prime inside n out and paint
it's colour is 'Ford Grey' by VHT, it suits me and it is high temp paint, now just to get the rest of it back LOL, cheers Dennis
25th March 2014, 07:42 PM
#10
I just recently got rid of my 2.3 Ltr 5 bearing stuff as I had stripped a motor with a punctured block,No 3 left via the side
I had a friend with a good block but no crank or pistons, so I gave them to him.
P.S. want a 24V Lightweight ?
