Results 1 to 10 of 11
Thread: Hello you beautiful landy people
    Jan 2014
    coes creek
    may i be a bother again i have become verry worried and my roadworthy i have heard that they need to see the chassis number other than the plauqe but i cant find it i know its normaly lhs rear spring hanger but theres nothing there are there any other places it could be many thanks
    james ned taylor
    ps series 11a 1969
    Nov 2011
    If it was a import from the UK rather than built here kit car, it might be on the front right of the chassis.
    If its built here is on the left hand rear spring hanger, you may have to scrub/scape away layers of crud/paint to get to it.
    If it really isn't there, you could put it there
    Jan 2014
    coes creek
    thanks but ive looked over it scraped every thing off and cant find it it on the chassis but it has the black and red plate with it on it has a made in aus badge so :s
    You may have to take it back to bare metal, and even etch it to show the number.
    The number should be on the vertical bit of the spring hanger just above the shackle bolt at the top of the shackle on the back of the back left hand spring, facing out.
    Jan 2013
    Central Australia
    I would have thought the plate bolted to the car would be enough?
    Check the front axle, at least mine has a chassis number stamped on it (although it's an early 2a so may be different?) But! beware, lots of these get swapped out so if it has a different number stamped on it probably don't mention it when you go over the pit
    Quote Originally Posted by Cobber View Post
    That is the axle number not the chassis number. Landrovers have always had major bits stamped with serial numbers, and initially they were the same as the chassis number for some parts.
    Gold Coast QLD
    When I took Ralph in to rego it, they didn't even want to see the car, They asked me for a VIN number but all I said I have is a chassis number. They said it was a 1964 6cyl petrol, I said 1966 4cyl Diesel, They changed the description on their computer and all was good. Out of there in 20 minutes. Must be some sort of record for Queensland Transport.
    1964, S2a SWB "Ralph"
    1977, S3 SWB "Smeg" (Gone)
    1996 D1 300tdi auto (Gone)
    1973 Rangie Classic (Gone)
    2012, 110 (Series 12) Puma "The Tardis"
    1962 109" Tray Back "Ernie"
    1998 D1 300tdi (Dizzy)
    2017 Kawasaki Versys 1000
    You must now cut down the tallest tree in the forest... With... A HERRING!!!!!
    scanfor Guest
    I can only hope that they will do that for me. I can't find a chassis number at all.
    Aug 2012
    Adelaide
    Quote Originally Posted by ezyrama View Post
    You must have got a nice person, they argued with me for 20minutes about the colour! I called it gold, they said it was mustard. So i said, yea it's mustard. That wasn't good enough, because on the road worthy they said it was a different colour again. Sooooo they needed to see the car. then the proceeded to argue about the configuration of the car, they said it has to be called a panel van.... 4 trips, a whole afternoon later i was ready to just burn the car in their carpark....
    But yea I had to 'found' the serial number on the spring hanger.
    Gold Coast QLD
    Yeah, she really didnt have a clue the poor girl. She said the numbers I gave her indicated it was a 64 LandRover 6cyl petrol truck, when I told her it was a 66 SWB Diesel ute, she had to go and get help, the new girl asked me what I thought it was and she changed all the info on the computer to reflect my description. Good Luck
