Have you tried M R Automotive at Redcliffe 07 3284 6688
http://www.mrautomotive.com.au/maxidrive.php
hi together,
does anyone know where to obtain crawler gears for the Defender. A under drive won't be suitable as I have a over drive I like to keep so thought low range crawler gears would give me best of both worlds?
Steve
84 Alfetta GTV
 Master
						Master
						Maxi Drive make 2 sets. From memory they were about 35% or 50%. The 50% are straight cut and can be noisy for prolonged stretches. That said they are great in the slow going. You can attempt rocks at slow speeds without running out of revs. I had a set fitted by George over at Landvehicle spares-Silverdale. He had to die grind some of the internal transfer case webbing away to fit the gear set.
