Results 1 to 6 of 6
Thread: IIA Radiators
    Adelaide Hills, SA
    IIA Radiators
    G'day,
    I just bought a used radiator for my 6cyl IIA and uploaded some pictures of the old and the new with some measurements, maybe this info will be helpful to someone, and maybe someone will know the differences between them.
    I put captions with the photos with measurements of thickness, hose size etc. The 2 radiators are the same height and width but different thicknesses.
    They are in my gallery "IIA radiators" if you want to have a look.
    Paul.
    http://www.aulro.com/afvb/members/pk...radiators.html
    Paul
    1971 IIA ute, 186 (Betsy)
    they're not dents, they're character...
    JDNSW's Avatar
    The square top radiator is the type fitted to Series Landrovers from Series 1 to 2a (four cylinder). They come in at least two different thicknesses, and outlet fittings are different from 2l and 2.25l engines. The round top is fitted to Series 3 and, I believe, Series 2a six.
    With appropriate hoses I think they are interchangeable, although not sure about the ones designed for the six.
    Mar 2011
    Newcastle NSW
    I just recently replaced my old square top for a new round top rad in my 59 Series 2.
    I found the bottom hose fitting comes out at a different angle. But the biggest difference is the height of the new unit compared to the old one.
    This upsets the positioning of the fan shroud in relation to the fan.
    I removed my shroud, I'm yet to find out if it's going to be an issue, I'm hoping not because it wont be doing any arduous work when it's up and running.
    Near Seven Hills, Sydney
    I have a Series 3 Britpart radiator in my 4 cylinder IIa, the shroud does fit without problem, I used a section of a hose from an unknown commondoor or foulcan to replace the aged hoses that my Series came with.
    Nov 2008
    Last weekend I pulled the radiator out of a wreck which currently has a Holden 202 but was originally a 2.6 litre Rover 6. I assume it's a 6 cylinder radiator. It fitted perfectly with the 2.25. The IIA and III radiators have different hoses but otherwise everything fits together.
    Adelaide Hills, SA
    radiator update
    I tried to avoid the cost of a recore on my original by buying another 2nd hand radiator, photos of both in my first post.
    I took the 'new' square top one to a radiator place for a clean and to have some leaks repaired and to have the inlet/outlet fittings modified to match the original round top one - but it didn't survive the process. SO, I took the round top one back for a recore (since that one doesn't need modification, has an overflow bottle, and folks seem to seem to think the round ones are better.) The radiator place says they can straighten the bowed bottom tank easily enough.
    The radiator guy told me a couple of things:
    - the thicker square top one would be harder to get air flow through so may not give better cooling than the thinner round top one (he said it would be like 'blowing air through a brick').
    - the bowed bottom tank on my original radiator would have required a LOT of pressure - not just from running a 16psi cap (which I did for a while, unaware that the IIA's system probably ran at about 11 psi). He said a failed head gasket could put enough pressure in to cause that, or maybe the car got really really hot, or maybe both (all are true, plus it was badly sludged up due to muddy creek water from its farm days).
    Have been taking pics of my (first ever) red motor head replacement will make another thread sometime.
    Paul
    Paul
