Your current rims are positive 33mm offset, the common approach would be to go to negative 25mm offset 16X8 steel rims. Gives you a 116mm track increase.
And is a legal rim size for 285s.
Not sure if you care, but are you aware that the max legal track width increase in NSW is 25mm?
