Eleven inch lift??? Surely that's a typo...
 Fossicker
						Fossicker
						Has any one fitted this kit was wondering about the height of the front shock towers ?
 ForumSage
						ForumSage
 ChatterBox
						ChatterBox
						Are you talking about the "extreme long travel" kit? (+5", works out to be about a 12 inch shock).
If so, I extended my front towers 50mm, I also plan to fit bump stop spacers, that's on a classic Rangie, but stands for Defender too.
Will
The only way to be sure is to get the relevant lengths with it sat on the bumpstops, get the closed lengths of the shocks, allow a bit for the amount the bump stops will compress under load and do some measuring.
I got away with running +35mm turrets on 12" 7100 Bilsteins with std bumpstops on a defender
 ForumSage
						ForumSage
						show me 2 different branded shocks with the same compressed length and ill by you a beer
Pete, did you have it sat on the BS while cross articulated?
 Fossicker
						Fossicker
						Terra firma make an 11 inch over length shock kit new mount etc
 Fossicker
						Fossicker
						Yeah dude, a guy on here fitted one a while ago and it looked insane. I'll try find his thread for you.
 ChatterBox
						ChatterBox
