The brightness of the tx led is directly proportional to tx power in a Codan. The radio is clearly transmitting, so it looks like there may be a problem inside the mic, maybe ptt switch, loose connection, or faulty microphone element.
Carbon elements can lose effectiveness if they are old, or have been exposed to moisture. They are easy to replace.
Since you were able to be heard nearby, I would suspect the mic element.
Terry
