Results 1 to 10 of 13
Thread: Welding stainless
    May 2013
    WA, South East
    Welding stainless
    Just after a bit of quick advice, and hoping this is the best place to find a decent and workable answer.
    I have come across some nice stainless rail that could be easily modded into sliders/steps for my 130, with a couple of quick cut and welds and some mounts.
    I have a decent mig, but want to know if I'm going to create any issues welding it with bog standard wire (gasless) or if I should go and get a new bottle, and use standard mig, or spend extra dollars on stainless feed?
    Thanks in advance guys.
    Adelaide Hills - SA
    I'm thinking TIG....
    It will probably weld with normal mild steel wire, but of course it will rust eventually. I've not tried MIG with SS wire, but it sounds possible!
    Any chance you can cut it all to size /make it fit and just take it somewhere to get it TIGged?
    May 2013
    WA, South East
    Quote Originally Posted by spudboy View Post
    The one thing I can't do in my shed currently...
    It almost seems like an excuse to buy a TIG...
    Recommendations???
    justfishing Guest
    Hello,
    You can get s/s wire but need a bottle of argon. welding with gasless not recommended it would crack it not hold for long but not for long and, the best bet is to get S/S 316 stick rods (arc welding) work great but wear glasses as the flux does fly off once the welds cools. TIG is the best but again you need a bottle of argon. Any welders on ebay are pretty good value for the home user. A couple of hundred dollars if serious then something other than a BOC as they are Chinese as ebay is better. Are you far from Perth ??
    Ian
    Feb 2012
    Carnegie
    I sourced some gasless st stl wire out of the states. For a MIG. Not used it yet. But it is available.
    Aussie Expat in NZ
    Not all BOC are Chinese, my 230 elite is a rebranded EWM (French).
    Aussie Expat in NZ
    If possible go to a welding store where you can try before you buy. I bough a Chinese TIG and it was horrible to use. No idea if i was just unlucky or spoilt with the other tigs i use but it was crap and then died. And it wasn't cheap either! (200AC). If i had tried it before i handed over my hard earned i wouldn't have bought it.
    May 2013
    WA, South East
    Quote Originally Posted by justfishing View Post
    Ian
    Cheers Ian, only a measly 700km South East of Perth. Not far really
    I'll look into the rods, I've got the trusty old arc here gathering dust.
    Sep 2010
    adelaide
    Done heaps. depending on the wall thickness of the rods.
    2.4 ss rods are easy to get, in NZ i could get 1.6 rods but have been unable to get them here.
    smooth rods to use to nice hiss but a bit wet so you will need to weld on the bench and roll your work,
    fitt and tack up on the top is ok
    Adelaide Hills - SA
    Quote Originally Posted by flagg View Post
    Yeah - my BOC MIG is a rebranded Kemppi, which is made in Finland, and has been an excellent unit.
