                                                15th March 2014, 04:05 PM
			Defender disc rotors
					Just tried to fit new disc rotors to my 97 130 Defender .
 I was sold PBR088 rotors , but after trying to fit the calipers , it seems the new rotors are a 6mm different offset to the orig .
 Can anyone tell me what PBR088 are for & what rotors I should have for a 97 130 defender ?
                                                15th March 2014, 05:04 PM
					088 is the code for rear brake rotors for the year model of your Landy for both PBR and DBA brands.
 087 is the code for front brake rotors for the year model of your Landy for both PBR and DBA brands.
 Both of these are OE replacements.
 Other codes apply for slotted and cross drilled versions.
 Edit: found a link to pedders website.
 Landrover Defender 1983-1999 90, 110 AND 130 Series Suspension & Parts | Pedders
 Mike.
					Reason: Website added.
                                                15th March 2014, 05:26 PM
					Thanks for the info , The existing rotors are 297mm dia with a 55mm offset , and the new 088 rotors are 290mm dia with a 49mm offset .
 So I am still none the wiser as to what is going on . Any help would be much appreciated .
                                                15th March 2014, 05:50 PM
                                                #4
					Mark's 4wd website lists 2 types for 93-2007 , RDA88 &RDA7019 [ 298mm ] , I don't know why the difference , but I guess I have the larger ones .
                                                15th March 2014, 06:01 PM
                                                #5
					I had the same issue with rear rotors that i purchased from ebay[rotor/pad combo], the seller claimed that landrover had two different options!!, the seller then replaced mine with the correct fitment rotors. 95 110
                                                16th March 2014, 06:25 PM
                                                #6
					I have been surfing the web for info , but not having much luck .
 Can anyone shed any light on this one ?
                                                17th March 2014, 09:14 AM
                                                #7
					It looks like  087 rotors fit the spec of what I have , but they are listed as   front fitment for  90 - 93  models .  does anybody know if they were fitted to 97 rear ?
                                                17th March 2014, 09:29 AM
                                                #8
					The DBA catalogue is wrong, and they don't seem in a hurry to fix it......
 IIRC the 087 is the correct disc for the rear.
 JC has listed the anomalies of the brake catalogues in the past, it's bloody frustrating....
                                                17th March 2014, 09:46 AM
                                                #9
					I had the same problem Search  Disc brake dismay bottom left on page fair bit of info
 AM
                                                17th March 2014, 10:12 AM
                                                #10
					Thanks for the replys , very useful , So what do the 088 discs fit ? so I can sell them to someone with the right vehicle .
