Results 1 to 6 of 6
Thread: how loose if the clutch pedal?
    Jan 2013
    melbourne
    I have had my '61 in dry dock for a few years. I have another engine fitted and bits and pieces of the body all over the place. I currently have the clutch pedal assembly out to replace the master cylinder (easier that way) and the pedal is quite stiff, in fact, very stiff. I have cleaned it all up and everything but couldn't get the bearing/bush out as I did plan to replace it while it's out. is a lot of stiffness normal or should it be floppy?
    Dec 2009
    Queensland (though occasionally elsewhere)
    If it's not connected to anything, it should move smoothly and freely. Sounds like it's a bit gummed up.
    Narre Warren South
    There's a 1/8" diameter pin that needs to be drifted out to get the pivot pin out of the pedal box. It looks it was originally inserted and then hit in the centre to bend it to stop it coming out, I replaced mine with roll pins.
    Once the pivot pin has been de-rusted and the bushes cleaned it will become loose again. There is a bolt in the end of the pivot pin that can be romoved for oiling/greasing.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Jan 2013
    melbourne
    Thanks guys. I managed to get the cotter pin out but can't budge the bearing/bush Might just drop it in to the guy who got the high tensile bolt I snapped in the flywheel, sure he has a press...
    Northern NSW
    I fitted a grease nipple in my S3 solved the problem.
    Cheers Will
    Jan 2013
    melbourne
    I got the cotter pin out and with the help of a lot of WD40, a drift and a big hammer, it all came apart. All cleaned up now, all nice and shiny and very floppy. Very happy here - and yes "will d8r" I too put in a grease nipple.
