Results 1 to 6 of 6
Thread: 240v Air Compressor Hose Pros & Cons
    Mar 2012
    Armstrong Creek, Qld
    I've purchased a 36 litre 2.5 HP compressor for the bottom shed as I got sick of carting the one I've got back & forth the 120 metres or so between sheds.
    My question is: Is there a performance difference between the normal, noncoiled, reinforced air/water line & the recoil type pigtail looking line. I'm thinking for, say, a 15 metre length that the non coiled line would be the go.
    Main uses would be tyre inflation & air cleaning using long/short pistol grip type guns.
    At present, on the old compressor, I'm using a yellow coiled line which seems to struggle delivering above40psi & I know it's not the machine!
    Steve
    Geelong, VIC
    Pretty much comes down to internal diameter of the hose, and length.
    Longer thinner hose will flow less than a shorter fatter hose.
    Different fittings on the hoses can make a difference too. I think some of that coiled hose is probably only 6mm internal, and its fitted over a male fitting so probably lucky if its got a 4mm hole through it.
    If it were me I'd probably look at some straight 12mm hose, with decent fittings, and ideally one of those retracting hose reels...
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Mar 2012
    Quote Originally Posted by steveG View Post
    Steve
    Thanks Steve
    Pretty well what I had in mind.
    Steve
    St Helena,Melbourne
    4.28 MB
    The coiled hose is crap, good reinforced 12mm hose is much better as Steve said.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Aussie Expat in NZ
    I was at my local Air Compressor place recently discussion hard points. Much cheaper than I expected.. Cheaper than a decent retractable.. Even with a few shorter flexiable lines. Also with ali hard piping avail up to 40mm the hard lines actually increase your air storage capacity. Just a thought
    Geelong, VIC
    Quote Originally Posted by flagg View Post
    Pretty sure the heavy black plastic pressure pipe for water is rated high enough for compressed air too (confirm for yourself though ).
    I've seen it on the side of the road in larger sizes
    Steve
