Thread: random aerial question
    Feb 2014
    Echuca
    hi guys,
    just out of my need to know stuff, what are those big (diameter) aerials you see mounted to the rear of 4wd's and caravans?
    I think what you are referring to are HF aerials.
    Jul 2007
    As a bove HF antenna, tuning network/mechanism contributes the the size. Usually the bottom part is thicker.
    Quote Originally Posted by benji View Post
    Maybe we're expecting too much out of what really is a smallish motor allready pushing 2 tonnes. Just because it's a v8 doesn't mean it's powerfull.
    One answer REV IT BABY REV IT!!!
    Feb 2014
    Echuca
    ahhhh, thanks
    jim bolton Guest
    HF
    Hi Geoff, have a look at "screwdriver aerial" I think this is what you've seen. The large diameter bit at the bottom contains a coil which is tuned by contacts moving up and down it driven by an electric screwdriver motor in the original version. Cheers, Jim.
