Checked the manual and yep, power window reset is in there. All fixed :-)
Hi all, had the battery disconnected after some work yesterday and power windows go auto down fine but no longer go auto up. Is there a way to reset so all windows go auto up and auto down??
Hi, sorry bring an old topic up but I can't seem to get it to work. Are there any special things you did such as engine off/on, ignition on/off, doors open or closed. They go down automatically when I unlock the car but won't go up.
Adam
Just add to this, I'm talking about auto up when locking the car, they auto go down when I unlock but won't go up when I lock the car.
If it's the same as a D4, you close window fully, let go and then press and hold up again. You should hear a click and auto up/down will be operational. It is in the owners manual for the D4 so could be also for yours.
Link to my D4 Build Thread
D3 2005 V8 Petrol
Ok I've tried every combination possible and still no luck. Just to be clear the Windows go up and down automatically when driving or the ignition is on, and when I unlock the car and hold the unlock button they all go down. The issue I have is the Windows will not close when I lock the car and hold the lock button. Any more ideas would be much appreciated.
I think I might try and disconnect the battery and start again.
Ok, that's different to the original poster so I misunderstood. Anyway, I think you're referring to Global Close on locking.
I have read that this is disabled for Australia. I would assume that would be true for all models. I think in some cars it can be enabled with the right diagnostic equipment.
Regards,
D3 2005 V8 Petrol
Thanks mate. Yes I've tried everything and it won't work. May be it is disabled for Australia. Just seems strange as global opening works just not global close. Never mind.
Now 2016 D4 HSE 'Leo' and Steve the Triumph Speed Twin
Then 2010 D4 3.0 HSE 'James'
Then 2010 RRS TDV8 'Roger' w traxide DBS, UHF, Cooper Zeons, Superchips remap
Then 2010 D4 TDV6 'Jumbo' w traxide DBS
First love 2002 D2 TD5 'Disco Stu'
