Results 1 to 8 of 8
Thread: Refuelling with a jerry can + the misfuel device - D4
    Hi all,
    Preparing for a desert trip, no long range tank so will need to use several jerry cans. Having looked in the owners manual I have read he following "The filler spout on some fuel cans and
    older fuel pumps may trigger the misfuelling
    device." I haven't tried this yet as plan to borrow some cans as part of a camper trailer rental.
    Also had come across this whilst looking for answers http://www.justanswer.com/australia-...ust-oztim.html
    My question is
    1) will this trigger every time the jerry can nozzle is inserted ( what kind of jerry can nozzle works )
    2) related to this what is a good siphon to have in case of dirty fuel
    Ellendale Tasmania.
    I'm not 100% sure, but I don't think this system is fitted anymore, my D4 doesn't have it, I've stuck all sorts on fuel nozzles in my filler without any issues.
    I will be getting one of these things very soon.
    Mr Funnel
    Home
    Baz.
    Cheers Baz.
    2011 Discovery 4 SE 2.7L
    2007 BMW R1200GS
    1979 BMW R80/7
    1994 Yamaha XT225 Serow
    NSW SW Slopes
    Don't put the spout in so far as to reach the mechanism.
    Quote Originally Posted by Redback View Post
    Mr Funnel
    Home
    Baz.
    Had seen those Baz on eBay, what size were you thinking of getting?
    Bangor, NSW
    Baz.
    Baz - you also have a long range tank and the mis-fuelling mechanism was probably removed.
    I have refilled a fair few times with a metal spout attached to jerry can and can confirm it does indeed trigger the mis-fuelling device - if (as Graeme said) - you stick it in too far.
    Rob
    Ellendale Tasmania.
    Quote Originally Posted by dukemasterpro View Post
    I think it says any more than 20ltrs go for the F8 or F15, I'm assuming the ones on Ebay are the genuine ones??
    Baz.
    Cheers Baz.
    2007 BMW R1200GS
    1979 BMW R80/7
    Sep 2012
    I've had it trigger once when I stuck the spout too far in; otherwise no problems.
    May 2010
    Southern Sydney
    I am also currently on a trip and carry two jerry cans. I have two metal Jerry Cans (Aldi) and purchased a Jerry can spout from Super Cheap Auto. I have used this three times without triggering the misfuel device.
    It is a little tricky as you have to tip the jerry can sideways to actually empty it. The top of the Jerry Can hits the car if you hold it at a right angle to the car (as you would normally do when pouring).
    My suggestion is just to get the standard Jerry Cans and Spout and give it a go well before you leave on your trip. It will probably just work fine.
    Peter
