Results 1 to 10 of 20
Thread: PC audio for dummies
    May 2003
    On The Road
    I have the normal 6 outlets on the back of the Motherboard,,
    I have a two 3.5 stereo push-in connectors with cable,
    however the cable has three wires, and after stripping both it seems there is bare copper and white common to both.
    what two do I use to push in to the speaker clamps?
    Mar 2010
    x
    You have two sets of cable, so left and right?
    The bare copper is usually ground, and assuming you are running a left and right you would just pick one of the white ones per speaker.
    I think thats what ya trying to do.......?
    Oct 2007
    Wantabadgery, N.S.W.
    The bare common wire will have to split so it can be fed to each speaker along with one white each. then you can trace which is left and right and swap over the whites if they're back to front.
    Mar 2010
    x
    But if he has the two cables, why split the common?
    May 2003
    On The Road
    Ok,, so thats works only--
    no volume out of speakers,,
    with the Realtek Audio manager at 100% I can hear music VERY softly,,,,
    This PC was set up to run a 5-1 surround sound.
    I am cannibalizing parts to set it up as a plain stereo in the caravan.
    Its like its missing an amplifier,,
    which it is I suppose
    Mar 2010
    x
    Sounds stoopid I know, but have you gone into settings/configuration of Realtek and told it just to play in stereo, not 5.1?
    May 2003
    On The Road
    yea,
    must be more volume in there somewhere--
    Gosnells
    - Pic of the connections/motherboard would be very helpful, if only to clarify whether you've got a stereo amplifier on the motherboard...
    ...or not.
    Mar 2010
    x
    Checked the Master Volume of the PC itself??
    It *is* missing an amplifier...
    The output down this very fine cables is not enough to run a decent sized speaker...
