Results 1 to 3 of 3
Thread: 1985 V8 County - Where are the Grease Nipples
    Castle Hill, Sydney, Australia
    Guys,
    I have found two...prop shaft and steering arm...but I am sure there are more. Any ideas?
    Geelong, VIC
    Tie rod and drag link ends may or may not have them depending on what has been fitted.
    Pitman arm balljoint may or may not have one.
    There should be one on each uni joint in the prop shafts, and one on each propshaft sliding joint.
    Could possibly be one on the rear A-arm balljoint but likely not (don't think there was one from the factory).
    Think that's it.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Near Seven Hills, Sydney
    There might be a grear nipple on the air con idler pulley, if yours is so luxurious?
    Not many otherss, I think Steve has them all.
    Oh, maybe on the steering column uni joints under the bonnet?
