Results 1 to 10 of 21
Thread: XP over and out
    Jan 2013
    Molesworth,Tasmania
    XP over and out
    who's still running XP and will you continue to run it or rush out and buy a new machine?
    I was thinking of upgrading this computer to Windows 8 but half of my programs would then be defunct.
    Not sure what to do.
    Any ideas?
    D
    Dec 2009
    Tyrendarra Vic (South West Vic )
    Going to run XP for as long as I can. 12 - 18 months I think
    mikehzz Guest
    XP isn't going to die and stop working. If you haven't got auto updates turned on then you won't notice any difference. All that is stopping is windows updates for it. The scare mongering that is going on is quite comical....there are evil hackers circling your xp computer ready to eat you...after whatever the April date is of course. It's called generating sales.
    Kiwiland
    Yes running xp on 2 computers still. No plans to change or update them.
    Jan 2013
    Molesworth,Tasmania
    XP - still in the running
    Thanks for that.
    I'm thinking I'll approach it on the same basis I deal with the Doctors. Don't do nothing until it turns black and is about to fall off.
    D
    Kiwiland
    Quote Originally Posted by Dark61 View Post
    Thanks for that.
    D
    Except for windows it all turns blue when there's a big problem.
    Nov 2011
    Aus
    Isn't it just the support that stops?
    Even on W7 I don't require their support...
    Nov 2010
    Adelaide
    Quote Originally Posted by s7000 View Post
    Yes, its the support that stops. By and large this means updates or hot fixes.
    So, when M$ find a vulnerability, they fix it. They won't be doing that for XP. While the bad guys will not be looking explicitly at XP, due to its dwindling use, they will try exploits for later systems to see if they'll bear fruit. (As an aside I am running Windows 98 virtual machines, out of nostalgia, and they still work just fine).
    The biggest issue will be peripheral support. Manufacturers just won't bother to write drivers for their gear that allows it to be used with XP. Some drivers (written for supported OSs) might work, some won't.
    Although most people with XP have all the software they need, its likely new programs won't work either. This might be because of the OS, or the hardware spec of machines still running XP. Open source software will likely be the only option as it tends to have a smaller footprint than the shrink wrapped stuff.
    If your XP box is still doing a job there is no reason to abandon ship...
    darwin
    Our office still has quite a few xp's in use,The problem we are having is that the original hard drives are now nearly to small to handle the new software we use.Xp is fine for general office work.
    Darwin
    03 disco 2a td5
    93 tdi disco [gone to a better home]
    2003 d2a v8 retired hurt
    1988 k100rs bmw gone
    85 county izuzu [gone to a better home]
    69 series 2a [gone to a better home]
    series 2a [gunnado]
    series 3 [gunnado]
    and the tinny
    Aug 2008
    Perth, WA
    Moved away from XP a while ago, avoiding windows 8 for the moment and sticking with Win7 and Linux.
    Have a couple of bits of software that still need xp but I just use a XP VM for that.
    Only concerns I have around XP are the people using it in a business environment. Bets on it not going well for the business if the old xp machine results in customer data being exposed due to unpatched vunerabilities.
    For home users it's going to be device support that kills it off eventually.
