Results 1 to 8 of 8
Thread: Copious white smoke = head gasket?
    Dec 2011
    sydney - pining for the western desert
    Like the title says...
    Td5 auto, 208k, just replaced turbo...
    No/minimal smoke on idle, huge clouds when the accelerator is pushed, whether it's in neutral or under load.
    A mechanic friend of mine has diagnosed a blown head gasket from this description. Is this a good diagnosis & if so where's a good place to get a new head gasket & what else should I look for when doing the job (other than plastic dowels.)?
    TIA
    Alex
    May 2008
    Bundaberg Qld
    Check you have not got a bad batch of fuel AND get a hands on diagnostic.
    A couple of us Landy nuts were moving a mate a few years ago and the TD5 amongst us started bellowing white smoke. The common thought was that it was terminal, but IIRC, it was bad juice.
    ZD 534 was the owner/driver of the TD5 ATT, so a pm to Glen might shed some light on it for you.
    drop the intercooler hose off of the manifold and start it up...
    if the smoke stops its not internal to the engine.
    May 2010
    brighton, brisbane
    From memory, white [ or white-ish ] smoke could be turbo seals [ oil] , unburnt fuel [ injectors] steam [ head gasket]. Check for white sludge under your oil filler cap, [ gasket] , and check the expansion tank for oily sludge. Are you losing coolant? Apart from that, I have been told a bad batch of fuel has been known to cause white smoke, although I have not experienced that. A diagnostic device may shed some light on the problem. Bob
    I’m pretty sure the dinosaurs died out when they stopped gathering food and started having meetings to discuss gathering food
    A bookshop is one of the only pieces of evidence we have that people are still thinking
    Oct 2013
    Nambour QLD
    I have had a car (not a land rover) lose transmission fluid into the manifold via a faulty pressure sensor letting oil through. Lots of white smoke as soon as you re-fill the auto transmission. Rebuilt the motor on that one for no reason I have a manual TD5 so I'm just saying. This is the sum of my white smoke experience
    Dec 2011
    So I did this (thanks Blknight), got marginally less smoke when I revved it, & a whole lot of black oily gunk coming out of the intercooler.
    This gunk could well be left over from the last turbo dying as I didn't flush the intercooler before fitting the new turbo.
    I've been losing coolant & losing oil, but there's no sign of cross-contamination between the two.
    So if I read this right I need a new head gasket?
    TIA
    Alex
    next step, remove the harness plug crank it and see what comes out.
    then remove the 4 glow plugs and check the 4 pots you can check.
    alteratively check the balance numbers
    you can also try a leak down check to ensure you're not just loosing compresiion out the vavles. (still means new head gasket but you know in advance what else is causing problems so you only fix it once)
    does the smoke go away when the engines warmed up and hows the blow by both hot and cold?
    Jul 2010
    Hunter Valley NSW
    If your TD5 is an EU3 15P engine, the EGR cooler coolant could be leaking into the intake tract?
