Thread: Vented disc calipers
    Landy86 Guest
    Hi guys
    I've been told you can change the discs from solid to vented and there's a part you can get to make calipers wider to take vented discs
    There meant to be longer bolts and tubes wit hoeing on each end to widen calipers
    Any help would be much appreciated.
    Landy86 Guest
    Sorry on a landrover 110
    Feb 2013
    Sydney, NSW.
    This thread might help you a bit for info on where to get parts from,
    http://www.aulro.com/afvb/discovery-...r-upgrade.html
    This thread for year models when vented disks came in,
    When? Defer Vented rotors & 24spline front diff.
    Also this thread, particularly what Dougal says on post 16....
    disk brake upgrade for defenders
    It is not just different calipers that you may need....
    Regards,
    Mike.
    Landy86 Guest
    Cheers for that 90
    Great help
    A kit is available from Davis Performance Landys. Whether it fits the Defender, I have no idea.
    Range Rover Modifications & Performance Parts - Davis Performance
    Safety Bay
    Calipers are cheap ex UK,I'd just buy the lot,rotors included and freight it to your door. Pat
    May 2006
    Woolgoolga
    That's what I did^^^^^
