Results 1 to 10 of 13
Thread: GSM antenna
    Jan 2014
    PNG
    GSM antenna
    With one of those external GSM antenna, say 860 mm, what sort of effective range do they deliver?
    apologies to Socrates
    Clancy MY15 110 Defender
    Brisbane,some of the time.
    in PNG it is very hilly?,so probably will not work well,except from top of a hill maybe.
    Mine is around 800mm,and is excellent out west where it is very flat,but around hills,not real good.
    Jan 2012
    Tasmania
    have been told by a communications Mate that in hilly areas the stick glass ones can work better. have both if then your covered.
    Jan 2014
    PNG
    Sorry,
    To clarify, for my Oz Defender, to be used out west
    schuy1 Guest
    Longer antennas tend to have a flatter radiation beam=better in flat country, Short 1's are lower Db but tend to have a higher angle of beam radiation, = better in hilly country.
    However that is just a general rule and being radio waves dont always behave as we think they should!
    Cheers Scott
    I've got one on the roof rack of my 110, and I loosen the U-bolt on the mount to fold it flat when not required.
    Travelling Central and Western Australia, I found it would get reception about 5-20 km sooner on an approach into towns, and keep it for that bit longer. At 100 kph, that's a maximum of 12 minutes of better coverage, but it does mean you can call sooner in an emergency, or extend your range and search the net sooner for accom / facilities if you're using your phone as a modem/hotspot for your tablet.
    On my next trip I'll have the phone plugged into both 12V and aerial patch lead, and switched to Hotspot, with a 7" tablet suctioned cupped to the windscreen, and that way even transient reception will give me a window of opportunity to receive incoming emails.
    Nov 2008
    Bruthen, Eastern Vic.
    GSM is limited to about 30-40km by the time based signal processing used (TDMA). You will get an improvement with an external antenna versus phone in the car, but no improvement between short, long or curly.
    NextG on 850MHz (and maybe 3G on 900MHz) is not limited by coding, so better antennas = better range.
    I get ~100km in flat country with a gutter mount ground independent with a 300mm whip with nextG.
    Terry
    Mar 2012
    Brisbne
    Quote Originally Posted by rover-56 View Post
    Terry
    got a link to the whip you are using?
    Ill be in the market for one soon but cant seem to find anything wrth buying.
    Leroy.
    Jan 2014
    PNG
    Jan 2014
    PNG
