Results 1 to 9 of 9
Thread: Transmission brake transfer box problems
    Narre Warren South
    A 2a parts car I've purchased is passing to a friend for use on his farm.
    Park brake was non-existant, very oily and the transfer box was very low on oil.Took the drum off last night and found this.
    More worrying was that you could move the rear output shaft up and down 5 - 10mm. I packed up the tools and had a think about it today.
    I think (any other ideas welcome) that the nut has come undone on the output flange and because the shaft is on taper rollers the extra play is letting it move up & down.
    The splines will be worn and the speedo drive possibly unservicable but at least if I degrease it, replace the output seal, tighten the nut it may be OK for farm use or until we can find a transfer box ?
    I've ordered transmission brake shoes as the ones in the picture may be past saving
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Dec 2009
    Queensland (though occasionally elsewhere)
    Yep, unless you can find anything obviously dramatically wrong, you're on the right track to clean it up, replace the seal and tighten things properly. That may be enough to bring it up to the serviceability you need.
    Agreed. The nut on the output shaft should be locked with a split pin.
    Narre Warren South
    Thanks guys.
    I'm hoping to get away with just degreasing everything, tightening the nut and fitting new handbrake shoes and a seal. OK for use on a farm ....
    The nut on the gearbox mainshaft that needs the special tool (or a chisel !) was loose as well. Mind you I was removing a Fairey overdrive and had to take a coverplate and gear from a spare gearbox and the nut on that was loose !
    More pictures to follow if I get time to work on it at the weekend.......I'm away in Country VIC and a branch fell on the house last night so I have a bit of clearing up to do when I get home.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    The nut on the drive flange does not set the bearing pre-load. It is set by shim thickness under the speedo drive housing. Set the pre-load by removing shims and testing with a spring balance as detailed in the workshop manual.
    Aaron
    Narrogin WA
    Quote Originally Posted by gromit View Post
    If it is only for the farm - degrease the shoes with de-greaser; boil some water in an open 20 litre drum outside somewhere where it is safe; add a cup of washing detergent and add shoes to the mix.
    The old boy who used to be the mechanic next door, said this was a common method after the war when things were hard to get, or hideously expensive. When I asked how long it took, he said "About the time to drink a carton."
    Let us know if either are true
    Cheers Charlie
    Quote Originally Posted by Aaron IIA View Post
    Aaron
    The nut on the drive flange does not set the preload, but it does apply it. So a loose nut means no preload. Ideally the preload would be reset, but for the specified application it is likely that just tightening the nut will be close enough.
    Narre Warren South
    Quote Originally Posted by chazza View Post
    Cheers Charlie
    Charlie,
    If you look carefully at the photo the friction material has all but disappeared, difficult to tell under all that oil & dirt.
    I remember someone years ago soaking oily motorcycle brake shoes in petrol, scrubbing of the worst of the oil then taking them out and setting them alight.
    Not sure if it worked but I wasn't game to go pillion on that bike any longer......
    With the current rain and clearing up from the branch that fell on the house I might not get to look at it this weekend....
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Narre Warren South
    Nut still split pinned but loose ? Maybe the transfer box bearings are breaking up.
    Degreased it and put it back together with a new seal. Still some play in the output shaft.
    Handbrake now works, until everything gets lubricated again....
    More info here :-
    http://www.aulro.com/afvb/holden-pow...s-202-a-2.html
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
